Help With Radiator removal!!!!!!
- Replies 30
- Views 1.5k
- Created
- Last Reply
Z32dave 12 posts
greg 4 posts
znut 3 posts
Giant slayer 3 posts
- Adjust your preference.
- Select Site settings.
Safari (iOS 16.4+)
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
Firefox (Android)
- Tap Notifications.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
Quote:
Originally Posted by Doobs too On an FAQ:-
NB Right and left referenced as if sat in the car (opposite to looking in the bonnet)
1/ Remove two air ducts from right hand intercooler
2/ Loosen bottom radiator hose and drain the coolant.
3/ Disconnect all hoses from radiator (two large, one small)
4/ Under the fan shroud is a flap which can be undone so the shroud clears the fan when you pull it out, loosen this (three snap type fixings)
5/ Loosen two top radiator straps and spin out of the way.
6/ Lift out radiator. :Quote
I'm using the above FAQ to change my radiator but am having some difficulty! :headvswal
My Zed is a Jap import N/A Manual and I've disconnected the top hose, removed the top radiator brackets, removed three of the four shroud retaining screws but:-
1) I can't reach the bottom hose to disconnect it nor the fourth shroud screw
2) I can't find the flap under the fan shroud which should enable the shroud to clear the fan
3) I have the Zed on my drive......must it be jacked up in order to access these items?
Some detailed info would be welcome as it's going to rain soon :cry:
Cheers - Dave
