In memory of Mandy
engine wiring loom
is there such a thing as an after market engine wiring loom to replace the old one and if so where could you source one?
cheers :)
speak to swz on here, or go direct to US z1 motorsport do them as does concept z in the US works out about £250 off the top of my head its for LHD but is easily adaptable missing sensors are wastegate solenoids, but if you have a boost controller it has its own solenoid so you dont need them anyhow.
No aftermarket, but stock replacement EFI looms yes. SWZ definatly have the Complete EFI looms in stock as I was looking to buy one for mine the other day - All shiney and new :)
cheers :)
As Greg says mate new ones are available in LHD form, just!
However it depends on exact year and if manual or auto as all are not the same, so make sure you get the correct one.
Is yours totally knackered ? or is it just the coil pack and injector connectors which are fooked which is often the case, you buy new looms for these at quite cheap money and they just splice in no probs.
Hope that helps
cheers
smithy
