can i use a n/a flywheel on my tt engine?? are they different???
please help!! :headvswal
You can, but I think you'll have to reposition the starter motor as diameter is different.
You can still fit it then. Just get an N/A clutch and space out the starter motor.? Not sure how long a standard N/A clutch would last though. Not long I'd imagine. lol
you will have to change the box too as the bellhousing is different so no not really !
why dont you just get a TT flywheel ?
Apparently not, they will fit the TT bellhousing according to something I ready from Andy Duff.
my car was an n/a i have almost finisied building my tt engine and in going to use the n/a manuel box but i only have an n/a flywheel and clutch ??
if you have a N/A box then yes you can use the na flywheel and clutch but be aware if you start going for more power you will fats run out of n/a clutches that will support it !
O.k si many thanks for your comments !
