part needed urgetn - any slough attendees got one ?
the bit coloured red here is what i need asap frown.gif it is the pipe to the clutch slave cylinder
and i will move this to forsale/wanted in a little while...
[This message has been edited by craig (edited 21-06-2002).]
partnr is 30855-40P01 ...
[This message has been edited by lymon (edited 21-06-2002).]
should be loads of pipe companys arround. got three down here in bournemouth. putec, hype hose and thread and pipe.
should only cost about a tenner! worth a few phone calls from the yellow pages?
cheers kris
Looks to me like you ought to be able to get a bit of braided made up to replace the whole lot. From the pic it looks like a screw in one end and a banjo the other.
If you can find the thread size I could probably bring enough bits for you to make one.
I'll be at SE tomorrow so I'll see if they've got summat suitable, if not then I might be able to get a handful of Goodrich bits that should enable you to knock something up.
from memory (while being nosey when the AA man was doing a temp fix), it has a banjo one end (thats the round thing at the cylinder end?) and the other end finishes with the plate that slots into a locator on chassis, and an inside threaded fitting, which the pipe coming down screws into with a standard 10 or 11mm bolt fitting (long sentence wink.gif )
the aa guy didnt undo the little bolt fitting, as it looks fairly crudded up and will most likely break when i try and do it frown.gif
but will soak it in "stuff" for a while first
[This message has been edited by craig (edited 22-06-2002).]
Hmmm, now I get 30855 30P01 - so what is the difference ??????
Anyway, Craig I'll be going on the North side of the M25, unless Sutton is particuarly close to Horton smile.gif
I think Eric's part number is for a LHD. I agree with Andy for a UK spec.
Don't know if this snap helps, if you are thinking about making one up.
30651 is the "alternative part code".
Good luck. Geoff
anyone know what pressure the system generates ?
ie, i guess its pretty unlikely i can blow down the pipe to find the hole... cos it dont show..
now to find somewhere to make it.. i guess sunday is very unlikely, so zedless tomorrow if i make it down frown.gif
