HICAS leaking
The power cylinder on my HICAS is leaking :eek: from the passenger side oil pipe.
Any ideas where I can get a replacement power cylinder from?
What do you mean by power cylinder?
It's usually just the pipes that leak...
ye theres a long pipe that does from the pump to the rack that has a 1 1/2" splice section on it (i dunno why, its so random) youl only see it if you rip off the foam insulation. check there first until your 100% sure its the rack
