rear fog light switch
Can anyone post a photo of a UK spec zeds rear fog light switch and its part number as I want to install one in my jap spec zed.
Thanks.
It's the same as the jspec's foglight switch.
Jspec has front foglights only, UK spec has rear foglights only. They both use a common switch.
okay cheers, will go off and buy any old switch then for the rear fog.
Think what Si is trying to say is the fog light switch is in the same position on all models just on the Jap spec it controls the front and the rear on the uk spec,if you buy another switch, where you going to put it??
Alot of ppl including my self have just bought an illuminated rocker switch and wired that in to control the rear foglight, i ran a wire straight from the battery a mini junction box(so i have power in the cabin and i know where it is and where it came from) then from the junction box to the switch, from the switch to the rear foglight.simple really.
Neil
The only difference between the two switches is that the symbol on the switch is slightly different. On the JSpec the lines, coming from the lamp pictogram, are diagonally downwards, right to left, and on the UK spec the lines are straight, left to right!
If you have a look through the second Word.doc of the Fog Lamp FAQ you'll find a picture of a nice round chromed rear fog lamp, these are available on the internet, and, imho, are a lot more pleasing to a rocker switch.
Dave
I have installed a rocker switch in the blank position beside the wing mirror folding switch, looks really good as it keep a standard look about things.
