anybody know where the bleed screws are? everything i've read says use them bot does'nt say where they are as i have done a coolant change and want to make sure all the air is out ;) cheers pete
top of rad on drivers side mate
found that one m8 it say's theres another two either side of plenum
you wont need to use em whereever they are,just slacken the rad one while the motor idles for 10 mins with heater set to full,then tighten and check rad level
i did a coolant change a few weeks ago. have a check of the coolant level a few days after you change it. mine was low. (sorry if i'm stating the obvious :slap:)
