boost leak tester.
Just recived a boost leak tester from z1 motorsport. Hooked it up. Used the compressor to apply air. But couldn't get any pressure to the system. Sounded juyst like the air moved around close to the MAF piping. have I done anything wrong or is just that I have a major leak somewhere near the front with the maf. (sounded like it came from the left side.) couldn't see anything from above the engine.....
Wish I knew how these worked!!-without 2 fookin' great corks up the Exhausts!!?? :confused:
I had problems when I first used one but have since used one on my car and another forum members and it's worked perfectly :) Needed to get quite a bit of air in before it built pressure ;)
Vijay
So nowt' came out the cylinders,down the exhausts?-do you keep the throttles closed? :confused:
I made proper bungs for the Zorst too but never had any luck even using my large compressor. :cry:
Well I guess if you had no turbos that could happen.
how and what can I do to check that the throttles is open?
look down to your feet and see iff its resting on the right pedal :D
