SPL Coilovers - anyone have them?
Im considering the SPL coilovers, they seem to be better made than the Teins and use a superior Mono tube construction.
They have excellent reviews in the states but does anyone in the UK have these fitted...would be interested in opinions if you have
I think SPL parts are top quality and I don't think it would take a lot to be better quality than Tien, but I'd wager these will perform better as well.
you thinking of a Group Buy?
what kind of Money are we talking ....????????
and do they come with all 4 upper and lower camber arm's
thank's wozza
They include pillow top mounts. The upper and lower camber arms are seperate.
Coilovers feature 8kg/mm front and 6kg/mm rear springs, adjustable shock length for height adjustment while maximizing stroke, 8mm diameter piston high pressure gas monotube construction, plated steel shock shell and aluminum upper mount. Shock is 15 way adjustable.
They use the same Spring rates as the Tein flex, which I've found to give a decent range of damping from soft to hard, but I've heard that these dont bounce around as much on rougher roads.
Im just waiting on getting a final UK delivered price at moment but they should be in the £800-£900 region.
Front upper and lower camber arms are approx £200 and £150 range respectively.
They use the same Spring rates as the Tein flex, which I've found to give a decent range of damping from soft to hard.
Front upper and lower camber arms are approx £250 and £150 range respectively.
how does the ride comfort compare to say the kyb eibach combo?
Deff up for some upper and lower camber arm's for the rear....
let me know the price ..;)
thank's wozzer...
thank's wozzer...
Always been available bud right here http://www.smithys-place.co.uk/susp.php
Fraid GB's is not something Kuah the owner generally entertains as he gives little discount to traders as it is, hence why the Powertrix suspension products, being pretty much the same, is cheaper ;)
smithy
Whats the metal sheeting for?
Air guides for brake cooling.
Can't see them on the spl site :confused:
Under suspension > front multi-link , about 3/4 down
Did you know that SPL is not using SPL coilover on his time attack race car ?
I'm telling you this but i don't know the answer of the question :)
They were using them back in Jan when they came 2nd in the modified class, beating much more powerfull Pro race teams. - http://www.300zx.co.uk/forums/showthread.php?t=94644
I dont know if they have changed yet, but they were looking to try Aragosta Coilovers, full race spec coilovers (not so suitable for road use).
sh#t, i was planning on buying some tien coilovers in a couple of months, i always thought they would be good quality.
looks like a change of plan!
