turbo timer sticky key
can anyother help. just fitted turbo timer 3 main ignition wires easy but left with thin brown and black. seems like these are both earth wires because it wont go until both are earthed out.
turbo timer working fine but key wont come out of ignition till timer has counted down. is there a wire i can snip on the ignition to do away with this
hope someone can help
thanks gary
thanks gary
anyone?
One of the wires goes to the handbrake switch, the brown one I thhink, so that the engine won't run with the handbrake off. This may also solve the key problem.
What type of timer is it? Try googling it because I know HKS have online instructions.
Darrell
yep the brown wire goes to the handbrake, the black is the earth but it won't solve the key problem mine does it sometimes it will some times it won't
