Been playin with the bleed valves on the zed today. The car is a uk manual and ive just had a new clutch fitted. So been waitin to turn the boost up a bit, anways i turned both bleed valves a full turn antclockwise and i got a fair increase in boost. the gauge used to read around 10 - 11 on the standard but now its readin around 14. i know the standard gauge isnt usually accurate but it still shows a healthy increase in boost.
I took the car for a road test and she feels alot quicker on boost, pulling really hard. Funny thing is it seams to be running loads better when accelarating. the car was apparantly fitted with bigger turbos before i bought it but had these replaced with a set of standard garrets. there is a BBR sticker on the back of the car so i had a look at the ecu and cant see any stickers on it.
Should i check inside the ecu to see if there is any signs of a different chip.
I know i can damage the engine if i run her on high boost without a decent chip, but as i said on the test drive the car ran great, the temp stayed the same even on full boost for a while.
Should i return the boost to standard or leave it were it is.
The bleed valves were already fitted to the car wen i bought her.
Any info would be great.
regards
George :cool:
