April 28, 200718 yr Is it possible that a set of 19 anteras from a 350z will fit my TT properly? the guy selling them does not know the offset, rears are fitted with 275/35 fronts are 245/35 will I have any probs? many thanks for any help.
April 28, 200718 yr think you may have a little issue with offset, 35-42mm on 300zx, but as far as i know the stock offset on a 350z is supposed to be 30mm, I may be wrong. think the pcd and the bore are ok, if you get the actual model of whel, you can check it online, think antera's are 309s or 369s, something like that anyway
April 28, 200718 yr 300ZX fitment dims here. http://www.carlsalter.com/old_wheel_fitments.html Think the rears should be a smaller profile as well. Check it out on here. http://www.rochfordtyres.co.uk/tyrecalc.asp Darrell
