Well after my dash pod saga screwed up i have comew up with another cunning plan
I am going to put my turbo timer where the clock is (not so uncommon) with my Apexi meter above it, along side that the boost gauge and in the place of the two top vents in the centre dash will go oil pressure and water temp, just need another dash to destroy now :)
What you lot reckon.
go to the back yard step and smash fvk out your hands with a hammer so ya cant do any more damage to your car :tongue:
If I do that how do I do this :xxx:
just ram your nob in one of the many holes you,ve cut in your dash :rofl: :rofl:
:rofl: :rofl: :rofl:
What I will do is get another centre dash and cut that up and see what happens.
You lot are so hard to please
you could roughly position everything on the dash you've already butchered make sure everything fits ok :rolleyes: , as well doin a Blue Peter attempt first before you do in another dash :)
hey scrawni your ok with the clock location, my turbo timer fitted in there nicley, i will take a pic if i can, looks factory fitted, i am now looking into fitting my apexi avcr & racelogic digital adjuster somewhere
i was thinking in the ashtray for the digi box, but the apexi im not sure yet,
ikarl seems the best idea locate everything where you want it then think about it,
remember MEASURE TWICE CUT ONCE !! golden rule LOL!!
Get a girl friend...or male friend depends on your orientation... :)
Change of plan again, I am going to fit them all in the top din slot, they should fit even though they are 68mm gauges so I need to find a new radio surround to chop up.
why dont you just get a pillor pod available in 52mm or 60mm saves cutting the car to bits lol
The gauges are 68mm mate and I don't like pillar pods
I had 3x 52mm Gauges in my DIN slot...that was a tight squeeze...not a problem if your going to start cutting it up and fabricate though.
If your having them in the DIN, or anywhere out of line of sight then Ideally you want Peak/Warning features.
Very old picture, before the Fabricated Screen :
