In memory of Mandy
Cheapest place for a heater matrix?
i got mine from ryan, but cant remember how much. I think im right in remembering that one from nissan is about 85 quid, and it was cheaper than that
Chris... i got mine from nissan, cost £148 (ouch) robbing Tw@ts
Didn't think it was worth putting a second hand one in due to the amount of work involved in an upside down position.....lol
primera one will fit with a small modification aparently... and will last forever!
Got mine from MJP but cant remember how much but he was well priced
Krysmayo got one from an eBay company. Not from a Z but better made (apparantly), although it requires some minor mods to install.
wasnt it a nissan primeara matrix that fits in with a minor chop?
Yes Primera one fits so might go for that but if I can find a proper Z one cheap enough I'd rather stick with that :)
im breaking miy old auto tt...i was planning to get the matrix out over the weekend do you want to pop down and give me a hand? :D
make me an offer via PM and i'll be a bit more motivated to get on with it
cheers
chris
Thanks but due to the work involved I think I'd rather put a new one in as they're notorious for failing shortly after :(
£172 :o
The Primera option might be the one LOL
So what exactly has to be done to fit it?
Am I going to need new pipes or tools to fit it?
Use your old pipes. Check for any damage first and solder up if needed as they are copper on the UK spec. Then I took the new valve of the Matrix and inverted it on to my old pipes. The control arm needs a bit of bending and bobs your uncle. You could just use your old Valve, but the seal matbe worn.
Sounds easy enough :)
ive got new primera matrix that i didn't use.had one made up locally for £90 so didn't use the primera matrix.don't know how much postage will be but if you want it make me an offer.
I Was Quoted £188 + V.a.t From My Local Nissan Dealers (stafford Park, Telford). Rob Doggin' Barstuards.
