Is there an easy way to inspect cam belts?
As per usual with in import , I have no idea if or when my cam belts have been done.
Before I wire up my boost contoller, I want to make sure the cam belts are ok.
Has anyone found a quick/easy way of removing the timing belt covers?
From reading replacement proceedures it seems like a right PITA.
Cheers in advance,
Andy
It's not too bad... just fiddly really - no short cuts though! And, you can't really 'inspect' the belt - at least not in a way that you'd be able to confidently say "yep, that'll last another 20,000 miles!" Not worth the risk if you don't know for definite it's been done imho, get it replaced!
i think youll find it will make life so much easier if u purchase this tool
its nissan part number is 0-5417
:rofl: :rofl: Quality!! :rofl: :rofl:
Any serious help?
DIY, took me and me old man about 5hrs, 1st attempt also
Wow that's impressive!
Did you do all the other belts and pumps?
Andy
Andy
Errm, no, just the cam belt :slap: :nono:
Should have done the tensioners and all the other parts as well but £ did not allow at the time
got the complete kit here:
http://www.courtesyparts.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=CP&Product_Code=Z32-120KT1
took me about 4 hrs to do the lot. is a fairly straightforward job on a Z32, once everything is out of the way there is loads of room to work! :)
hello paul mate... did you buy this kit from the us? how much did it cost on ur doorstep all in? are all the bits good for a uk spec (other than one of the drive belts)?
Joel
not sure on exact cost as I bought loads of other stuff at the same time LOL! still got roof seals, door seals & targa seals to fit :smw:
mine is UK & all fitted fine (got my kit minus the belts as I have an underdrive pulley anyway ;) )
was the import tax heavy?
Not if it's shipped as a gift or sample or better still use USPS! Most will send using the United states postal service! Just try and avoid UPS!
http://www.usps.com ;)
I did the same, I always change the belts on all the cars I buy. Cheaper than having to buy a new engine.
If you want a kit we can just put an extra one on our weekly order from the states if you like ?
Hi Paul how much is the kit and what do you include?
Also, how much to supply and fit and how long would you need the car for?
Andy
SWZ 60k Service Kit
Cambelt
Waterpump
Thermostat
Rubber Water Inlet hoses (2)
Auxillery Belts (3)
£190
60k service supply and fit is £375 (Can usually fit the job in with 1 weeks notice)
Extras
Cambelt Tensioner – £110
Idler pulleys (2) - £70 each
All Genunine Nissan OEM Parts.
Prices include VAT and Delivery.
I've always found this tool a good friend mate.
Part number 666-666
Ivan
Part number 666-666
Ivan
Good but not good enough - thats an imperial one :(
Well spotted Mr Duff.
This site is full of ****ing amatures.
Andy
