it wont stop leaking
hiyall
need help quick my zed burst a water pipe before crimbo on the water outlet i got a new 1 but when i filled it back up with antifreeze and water its leaking from somewhere else and it seems to be in the middle of the engine as its running down the front of the sump and i cant see where its coming from i know you cant see it for yourself but i wondered if anyone knew what it could possibly be
any advise is welcome
cheers in advance
hiyall
cheers in advance
1 water pump
2 the 2 small hoses that go onto block in between the ally pipes
1 water pump
cheerz mate
have replaced both the rubber pipes on the ally outlet/inlet pipe as these were the ones that burst will try water pump as she's in for crank oil seal doing this weekend
many thanx
make sure you have a decent seal around both ali pipes as it could be weeping out between there, as your changing the crank oil seal you will have to do that anyway :)
cheers for that
Did you check the metal hoses that the rubber goes onto for corrosion (the ones that go to the heads) when you replaced the hoses? These often corrode and cause it to leak...
