Help lamda sensor under turbo's
Just fitted or should I say am trying to fit new de-cat pipes on my tt, the shiny stainless steel ones fron 2fast2cool (ebay) which replace the down pipes straight from the turbos.
They come with blanking caps where the lamda sensors are supposed to go.
Existing ones are shot!!! Should I replace them or just leave them off as I will not be running cats??
Help!!!
Thanks in advance,
Andy
The only reason i havent bought these pipes yet is because I was unsure of the positioning of the lambda sensor holes, are they in a good place?
And to answer your question, YES replace them! Don't run without them. Soooo much easier if you have the downpipes off the car, as you have.
No problem at all with the postion of the O2s on these DPs :)
good good, i'll be going ahead in due course then ;)
Cheers,
Andy,
Are you saying that I can put the lamda sensors on once the pipes are on?
Yeah its easy possible but MUCH easier when off the car!
