Neutral switch.
I am in the process of doing a manual conversion. Can anyone tell me the purpose of the neutral switch on the manual gearbox, do I need to worry about it?
I seem to recollect that if the clutch is depressed and the box is in neutral then the revs are raised slightly, or something similar. Try a search, I'm sure I've posted something about this in the distant past.
Oh, I'll join you in this as I'm about to do the same, if the rain ever goes off, grrr.
How about we post pictures here, for each other and everyone else thinking of doing it?
Pictures of the cars of course :)
other way around ;)
the ECU "senses" when the car is in gear and adjusts revs and timing accordingly
the sensor itself is loacted at the back of the gearbox, nearest one to the shifter
Cheers, just looked up on diagrams and found it.
