To every body (MY Z group frinds )
hiiii
:headvswal
300ZX TT vs CRX
befor 2 days
I testd my Z with honda CRX
round 1 :
I start leat
but we going agine
roung 2 :
my frind told me remove (sum house ) to more boost
after race ( not complete )
but :rant: my engine smoke & 1 cilinder i think broken
what hapin ?
tall my ?
sounds like you are saying that you pulled a hose off the wastegate so you get more boost, unfortunaltely it sounds like you've killed your engine. You have had too much air and not enough fuel which will casue detonation and KABOOM
anyone got a universal translator? Sorry i dont speak Klingon!
Anyhow it sounds bad, blown gasket or dead piston perhaps
pmsl :rofl: poor guy leave him alone :D
Yep sounds like the waste gates were stopped and the whole thing exploded :( unlucky :(
a knackered one by the sounds of it
BORAT has a Zed :) :) :)
:rofl:
No match for a z but crx's are pretty quick, more so when modded.
oh dear never mess around with something you dont understand!!!
as £££££££ will most deffinetly follow.
Car = ****ed.
You need = Texas Instruments' Speak 'n' Spell.
get it to a z garage from on this site put up where your from and someone will reccomend a garage to take it to. i would start messing about yourself as it could end up costing more
Judging by the location of the battery, I'd suggest that he's not from this country.
too much boost dude learn your lesson dont mess with what you dont understand you now have half a piston congrats
my frinds
now my z ready & I taked from garage
but the oil bump curve is down .. we dont have spearpart
sound ( tik-tik-tik-tik) from engine
& the power ( speed not like before ) oil bump the Reasoned ??
tell me what can I do
my frinds
vigon my friend, where do you originate from as we are having a little difficulty understanding you?
Sounds like you should have left it at the garage.
Actually, that's probably not such a good idea if after they've worked on it, they give it back to you and it's still ****ed. :wack:
I will change oil pump
Is the engine will force the past
tell me What happened Exactly to my engine & oil pump after rendered happened happened
What on earth? That makes as much sense as Kim Jong-il's North Korean dictatorship.
:D
Where are you from, our kid? Translation; What is your country of origin? :D
ok let me try here
You have a sharp ( spearpoint...good eh ) sound coming from your engine and power is down and you have low oil pressure after removing the wastegate solenoid pipe
I would go for you still have a broken piston in there...do a compression test
COMPRESSION TEST.
