mm, now I've got mi racelogic fiited am having some more problems, the car missfires at light throttle in every position on selector switch, apart from off, also it seems to work and my wheel size is correct what else can it be??
richard
  • Replies 26
  • Views 1.4k
yes its set up for 46, i tried it in every position on the selector and it misfires for nothing even at low speed
and light throttle????
Sounds daft but are the wheel sizes setup correctly? Can you post screenshots of your setup?
switched mine off
cant work out best settings.
mine nearly killed me a few weeks ago
going round a corner in the wet it started to cut power and misfire, so I just held throttle position and let it do all the work, then a big bang and surge of power and all hell broke loose, car went sideways, I steered into it but sh1t me pants coz I wasnt expecting it at all - lucky no one was on opposite side of road.
I was after the setups for wet and dry a while ago.
Cant remember what my settings are at mo.
if anyone has all the settings they have (apart from wheel sizes), Id be grateful.
I've got a racelogic setup programme done by a Z owner with all the settings if that helps???
Vijay
could you mail me a copy of ur bin files so i can compare settings cheers
andysend us ur mail addy so youcan look at my settings see what you think??
richard
Not sure about bin settings but it's a small programme that will set up the racelogic and then I have screen images of the settings :) what's your email address?
Vijay
hi mate mail me at sykos1@talktalk.net
vijay if you open up the racelogic programme and read ecu you can then save file as and name it then thats ur bin files which you have to open up with racelogic to see em lol
cheers richard
Vijay
cheers richard
any chance of forwarding screens to me too please
I got the program - just needs the screen dump settings :)
I have some 300zx setups on my laptop (when I can dig it out) others can try if they wish? My interface pages are different to those posted what age is that one. I think my one is mark2 about 2004/5. I'v had hours of fun playing with setting and testing using the built in graf data log, anyone with racelogic should learn how to use it. The setup you need will depend on the power level of your zx. The data log can also be used to find the problem if you have miss firing.
cheers guys I'll give these settings a go
richard
Richard, from first glances the config seems ok. Have you checked to see that the box is picking up all 4 wheel speeds and rpm signal?
Cheers,
Andy
sounds like driven wheels & reference wheels are not set up right. check first. ;)
I spoke to him in cyprus lol, andy, I checked my speed sensors and im not getting a response from the front left (green wire abs) checked wires to abs and continuety all ok at race logic ecu but run diagnostic graph and still no readings wtf checked ohmsreadings on all 4 sensors and getting about 1k across sensor, butif i try reading ohms on 1 side of sensor and ground(as per instructions in rltc book) i get no readings on any???now am confused
and no and am not checking wrong side of sensor
so this might be my problem
anyone???
if it was an ABS sensor fault then your ABS warning light would be on - more likely a wiring issue to the RLTC unit, are you sure its been soldered in correctly?
nope my wiring is soldered spot on I double checked and ohms reading at rltc unit,
but I have now found sumat else ffs, I used the other software not the dos type,and put it in monitor and am getting al 4 speedsensor readings , some read more at speed, but i have all 4
so it must be the latest software from rltc thats not quite right,
can they be mixed and matched ie load upfiles from one and then readthem with the other software??
richard
just checked reference and individual wheel wheel to see what wheel id is with older rltc prog in monitor mode, wheel 1 is left rear
wheel 2 is front right
wheel 3 is right rear
wheel 4 is front left
so reference is set at 2 and 4
side assignment 1and 4 this was 2and3
sofront wheelswere wrong way around but would it make that much diffence??
also wheel sensor on front left won't show on test by spinning wheel as it only reads it after about 10 mph lazy sensor possible.
havent tried it with new refernce setting but car missfires a low speed and light throttle and i had the arse end out from roundabout in wet setting ffs
:slap:
if it helps , im sure cybernet is a registered trader and sells these , my guess would be he knows how to set this up !!!
Yeah the weird thing is that Rich has installed the RLTC on someone elses car & used my settings file with no problems, worked straight away. Just on his car its having mental problems.
do you have access to another RL control unit that you could swap??
I can borrow my mates next week when hes dropping it off for his engine swap
i might have to try his on mine and see what happens, fynny thing is when i bought this rltc from cybernet's group buy the origional ecu wouldn't communicate with my lappy or carputer , he changed the ecu and hey presto files uploaded no problem, it would be very rare to have 2 faulty units albeit it being totally different faults ffs lucky me
richard
