rear bumper
hi to everyone . need help . is it easy to take the rear bumper off a zx tt . had a quick look today and seen loads of bolts . having ago tomorrow as car is in bodyshop having some work done . any info and or photos would be much appreciated . :bow: :bow: :bow: :duffer: :duffer:
undo all the 10mm bolts you will see them once you have removed the interior panels then just pull it off.
Don't forget the two bolts at the bottom corners of each side and tops of the corners and all the little plastic expanding rivets that hold the base of the skin to the rear panel at the bottom.
