Side light / fog light bulb replacement?
I want to replace the side lights and fog lights - I've got new bulbs to match my HID headlights colour.
The problem is fitting them.
THe instructions say remove the indicator housing - no problem.
Then remove the three bolts holding the side/fog light housing in place - I can only see one peering in throught the hole where the indicator was.
Any ideas?
Cheers! :duffer:
10mm (I think) Spanner. Two at top, on the left and right hand side and one on the bottom center.
you have to put your hand in thw indicator hole and feel for them.
Had mine out yesterday, just feel around with your hand to locate them and then you know where to look. The bottom one is behind the wiring plug so you need to unplug it to get to it. HTH
