Urgent advice required about breather kit !!
Hi Guys
Just started to take my breather kit off and I need to ask some advice. I purchased two new pipes to the crankcase REF: 11823-40PO1 and 11823-40P11 (thanks for the part numbers Eric ). I need to know which pipe goes on which side of the car. I also need to know which way around they go. As Lack300 said (in my last breather kit post) the stock pipes have a restrictor and a brush type thing inside. Does the restrictor face up to the crankcase pipe or down to the large round black hardpipe???.
I would be very grateful if anyone can tell me which way these pipes connect on. PleasePleasePLEASE!!!!!!!!!!!
Cheerz
Simon H.
BTW Thanks again Eric for the info on the part numbers for the pipes. Nissan had them in stock luckily. You were right, the bloke that installed the kit did throw the stock pipes away!!!!
Simon, the 40P11 is the (RHD) drivers-side hose.
hope this helps !
Eric
[This message has been edited by lymon (edited 26-04-2002).]
Simon mate,
If you get shit out of it and lost for pipe routing and the like I will drop my car off for you to use a reference tomorrow (Sat) after work.
Can leave it with you for as long as you need it - I dont use it much anyway and I can come back and pick it up in the week..
Glen
Thanks for the info Eric, I will have another crack at it when I get home.
Cheerz for the offer of the car Glen. I think I should be ok if the pipes can only go on one way. I will give you a bell later today about sunday M8.
Seez ya
Simon H
