Part codes
Is there anything online with all the part numbers on.
Just I have a few bits to order and dont want to describe everything to Mr. F. Would be nice to give him codes.
Thanks.
Well one I can not find is a gasket that goes on the front of the turbo. Diamond shape.
Sorry for the delay, but I was eating my tea :D
Well it looks like it's not available separately, but is only available as a full gasket set....
10101-40P87 Gasket Kit- Engine Repair
Dave
Bit of a hint - if you're getting more than just a few gaskets then its worth buying the engine rebuild gasket kit. Just the HGs and the lower inlet manifold gaskets cost about the same as the full kit.....
Not sure on the part number for that one though - FAST cd doesn't seem to have it listed...
Full gasket set as in the whole engine set?
Im getting the cometic 1.2mm metal head gasket.
Lower inlet manifold I have.
Got the codes for the other ones I need that I dont have.
Just need those turbo ones!!
Sorry bud, I can't find the part separatley. Your best bet would be to give Mike Feeney a call on this one.
That's the problem with the Nissan Fast system, it's a right pain in the arse to navigate at times ;)
Rodders, I may be wasting your time here but I might have those gaskets from when I rebuilt my first Zed. I'm not sure so don't rely on it but I'll try to get to where my stuff is and check in the next few days. I can't remember if I ever chucked them. I also had the head bits and some other un-used stuff.
