ECU pin information sheet
As above anybody got one, need to know what the pins do, trying to wire up a meter and after a few things, the diagrame i got with the meter don't look nothing like the ecu wiring i have, it's a jap spec auto 92 if that helps
Cheers ppl
Neil
Spac spec auto 92 if that helps
Cheers ppl
Neil
Spac spec LOL, auto then :x: :x: :nelson: :mac1:
GOt the pin numbers nowjust needtoknow what they all do, any ideas as to where to find this? looked through the on line service manual butcant seam to find it? any suggestions??
What are you like at reading circuit diagrams ?
There is all the info you need if you know how as you can see where each wire goes which will tell you what it does.
If you're after specific items, let me know and I can trace it for you.
Depends what you need. There's some pin information here - http://www.twinturbo.net/ttnetfaq/FAQpages/ecuharness.html
That's the pic i have,
The pins i'm after are:
12v constant
Injector signal
no.1 ignition signal
Ground
Vehicle speed sensor
IG power
crank 180degree signal
crank 1 degree signal
airflow signal
if you could let me now what pin numbers they are that would be great.
Neil
12v constant
Injector signal
Ground
IG power
airflow signal
Neil
Speed sensor is pin 53
AFM is 26 & 27 from the previous diagram
Ground is 50 and IG power is 59 from http://www.twinturbo.net/ttnettech/avcr/avcr.html
I'm sure I've seen the info on the crank sensor too, but I can't remember where.
Try this my man ;)
Now that should be in the FAQ section. :bow:
Looking through there are 2 cam posistion reference signal 's would 1 be the crank 1 degree signal and the other the 180 degree signal?? if so takeit the first on would be 1 degree and the second 180 degree???
cheers
Neil
VG30 CAS has 1 deg and 120 deg outputs due to being a V ;)
Andy!! been waitin for your reply Mr Know it all lol
ok did i identify the right pins?
Doesn't look like you need my help any more :)
Well still not quite sure, onthe crank angle sensors, so if you have any more help......
I *think* the reference signal is the 1 deg, and the position is the 120 deg. Not 100% sure on this though. 41 & 51 are the same and 42 & 52 are the same - the connections are bridged in the harness ;)
cheers mate your a star. however does this mean that the apeximultichecker i have will not work properly because it's after a 180 degree sensor input?
Neil
Found it!
41 & 51 is the 120 deg signal
42 & 52 is the 1 deg signal
EF&EC 107 in the service manual :)
Found it!
Top man!
but as my post above? will it work correctly?
Neil
And that's what i got sent with the checker... should learn to fooking read really!! tipical bloke thing i think!!! lol
LOL!!! No probs mate - gets a bit daunting when there's more than a few wires to connect so easy to get the odd spot of blindness ;)
