!!URGENT!! zed specialists help needed in the London area
Well the saga continues...got the car back yesterday and low and behold as ever there are problems....to me the car is only performing half as well as it should.
Now in fairness to the guy who used it for filming he has put all his trust in a local specialist and they have let him down by doing half a job. He did offer to take it back having dropped it off last night and come back today to have a look at it but I said I'd rather get someone from here to take a look this time.
The car is about half as quick as it was with the knackered tubs and I think the best thing would be a conzult to suss things out. It does smell quite badly of petrol and the after market boost gauge doesn't cross 0 bar....neither does the stock one.
I know its a big ask but I had booked next week off (25th onwards) to spend some time driving the damn thing and was wondering if anybody on here with some know how could take a look on tuesday or wednesday or poss tomorrow evening? I'm not asking for a free lunch the money to pay for the work is ready and waiting its just I really want this car running properly for the first time. :cry:
I haven't got a scooby how to check anything myself but am willing to learn if shown.
Many thanks
Rob
PS.spark plugs changed and coil packs checked already
  • Replies 36
  • Views 1.9k
what about southwestzeds?
He's a great guy but too far away from london mate.
try doing an ecu check, see if it comes up with anything first http://www.ttzd.com/tech/diagnostictech.html
I'll have to try and get hold of something to undo the bolts then...I'm always moving around so the minimal amount of tools I have are back in Brum and I'm in an apartment in London at the mo. Is the zen garage near londaon?
If you were able to get it up to Stansted direction one evening this week I could take a look at some stuff for you.
That would be amazing mate I can do it tomorrow evening if that ok with you? Where exactly are you....the car drives ok its just slow!!!!! Oh and smelly!!
Rob
Hello Rob,
Easier way to do an ECU check in 2 mins ;) http://www.twinturbo.net/ttnetfaq/FAQpages/ECUdiagnostics.html
Mark (Zen Garage) is Putney way I think :) Where abouts in London are you?
Vijay
Just spoke to mark...great chap he offered to take a look on tuesday but he can't spend too long on it because his workload has him stitched for a month.
Can't begin to describe how much this car is annoying me now and I'd just booked time off to use it!!!
Rob :mad:
Rob :mad:
get used to it bud :rofl: :rofl:
I'm a little too familiar with it already!!! Nothing but trouble but ya gotta love em
you certainly have olly, they are like a drop dead gorgeous bird no matter how they treat ya you still go back for more
Did the quick check and the engine check light flashes 5 times slow and then 5 quick...is this bad? Oh and how do I turn the test mode off with the piece of wire?!!
Mine is just bugging me now its so close to being right I'm sure but I am baffled as to this continuous bad luck.....no smoke anymore but its 10 times slower than with the screwed tubs!!!!!!!!!!! :rofl: :rofl: :rofl:
5+5 = 55 no errors detected
you got code 55 which means no fault found read fault codes on here http://www.ttzd.com/tech/diagnostictech.html ive not done ecu check that way but i would guess if you start the engine it will stop it or if you re-attatch the wire it might stop it, but i do stand corrected if im wrong.
Anyway that illiminates code 34 (det-sensor) which would mean the car would of been in safety boost.
where does the boost gauge go up to, when you boot it?
Of course Fook me I'm daft sometimes. It has been suggested that a massive boost leak is the problem.
Oh by the way Greg hold those mirrors please if you can!!
Rob
It goes only as far as 0 and not a smidge futher.....
then the tubs aint boosting could be possible you have sized turbo as was case on 1 of my zeds or a huge boost leak check the large pipes either side of plenum to see if any loose you might have to check the intercooler pipes too
Is a seized tub unseizable they were extremely low mileage ones from jaypsc so I'm sure they are ok....
if a tub is siezed they usually had it, if you could unsieze 1 it wouldnt be any good as the bearings would be shot, if they are newish tubs it could be possible a waste gate is stuck open so all the boost is going straight out and not getting into the intake. Take the large pipes off that go to the turbo in there is an impellor check to see if that turns fairly easy with a minimum of play, if the impellors turn the tubs arnt siezed then i would say a boost leak or waste gate stuck open its a pig of a job but it will illiminate the tubs
I wouldn't even know where to start....probably do more harm than good. Do you know anybody who could have a look for me in our area....I'm in Docklands East london.
Of course I'll be paying I don't expect anything for free.
Rob
Rob
ok rob, will put by for you for a week, after that there back up for sale bud :)
Are you sure they replaced the knackered tubs????
I`m no expert but if they frigged the wastegates open permenantly wouldn`t that give the same symptoms? The tubs wouldn`t smoke cos they wouldn`t be boosting and the car would be dog slow.
Is your boost gauge working at all?
As said above, a seized turbo would give you no positive boost so the needle would only reach zero :( It happened to me an turbos had to be replaced :(
A siezed turbo will give no + boost
an open waste gate will also give no + boost
as would a boost leak on any of the 4 large pipes either coming from the turbos to intercooler or from intercooler to the intake all pipes need to be checked could even be a hole in 1 of the intercoolers or a leak on the balance bar.
Code 55 tells you nothing is wrong on the electrical side so its a mechanical fault you have all the above need to be checked out
