Oil Change/auto Box????
hi peeps,going to change my gear box oil on my jap auto but cant find the drain plug anywhere,i can only assume i hav to take the plate off underneath,thats not a prob as will clean the filtre at the same time,its gettin that blinkin gasket,need 2 of them as want to flush the system out,and a couple of fluid changes should do the trick,can anyone tell me where i can get them from,many thanks in advance
http://zhome.com/ZCMnL/PICS/autoTrannyOilChange/autoTrannyOilChange.html
try MJP in the traders section or here http://www.mjpauto.com/
cheers
I did mine without changing the gasket......no leaks.
I got a pump from DemonTweeks for sucking the fluid out of the gear box through the filler pipe....If you drop the pan you you get deluged in oil....Plus you need to do a couple of changes to get any where near clean oil as you cnat get at the oil in the torque convertor....which has half the oil in it!
sounds like a good idea,was thikin of something like that myself,was going to try and drain it from the oil cooler i put in,will look in the local factor shop 4 a pump,many thanks and keep up all these blinding ideas :)
Only prob with the suction method is that the filter don't get cleaned/replaced
and any sludge in the sump will stay there!-up to you dude! :)
Sorry - meant to add that after you have siphoned out the oil - you can then safely remove the sump to clean the filter.....Thats what I did with mine anyway.
no probs mate,was going to do the filtre after i drained it,just a fookin pain havin no drain plug,plus gear box oil stinks,cheers :)
