cruise control on light
i noticed a problem with my cruise control light yesterday. I pushed the master switch a the first green light came on, i set my speed with the stearing wheel buttons and the second green light came on on the left of the wheel panel. when it was reset when pushin the brake extra the second light went off but when resumed or set at a different speed the second green light would come back on. i tried to reset the system by turning off the master switch and turning it back on again but it seems to be on or off when it feels like it. any advice guys?
The first green light just tells you that the cruise control is 'armed' for want of a better word, the second light tells you that it is actually operating.
yeah it is the second when that is not always coming on. It is an intermittent thing. Sometimes it works sometimes it doesnt but the actual cruise controling works fine so is it some sort of power supply problem to the bulb?
you have to be going over 50 mph as well for it to set...something you dont get to do very often in London......:)
Cruise onlyworks from 35 to 72 mph on imports
And 50 to 100 ish on uks
If you brake or press cancel it will turn off.
