IAA Valve and FICD Valve readings
Hi,
I have taken a reading between the FICD valve terminals on the IAA valve and got a reading of 25ohms - I think I read somewhere that it should be 75ohms - is that correct?
BTW getting the IAA unit off is a complete b****
and as for the Air Reg - the bottom bolt is blind and I am having extreem problems getting to it - any ideas anyone?
Next Q! Anyone have an IAA unit for sale - 4 A 1990 JAP TT?
Cheers guys and best regards.
AndyGP
FICD should be approx 22-25 Ohms
AAC should be approx 10-11 Ohms
Air Reg should be approx 75 Ohms
As for removing, try a short extension bar on a socket, a flexi/UV joint is also nice here.
When you refit it, junk the hard water pipe and replace with a 6mm silicone hose, makes the job a ton easier!!
And finally, yes i have a spare one somewhere, ill get back to you.
Thanx Ollie - sounds like mine are ok - FANTASTIC.
I will give them a good WD40'n whilst they are out - and then proceed to remove the remaining skin from my knuckles as I go back in for the Air Reg - lol
:dance:
Cheers again.
AndyGP
... I will check the reading on the Air Reg (75ohms tomorrow as well).
Cheers Ollie
:dance:
Air Reg is easy once you have mastered the IAA unit ;) just remember to bin that annoying metal pipe bracket! You can completely dismantle and clean both the Air Reg and AAC for a good clean with wd40 - like so:
When i did this i found my Air Reg spring to be broken, so worth a check.
Hi,
Just to close this thread -
With many thanks for the advice provided - I managed to get the Air Reg off in about two minutes - FANTASTIC! All cleaned and ready to go back on... ;)
My AAC measured @ 15ohms (11ohms stated)
My FICD @ 25ohms
and my IAA (Air Reg) @ 80ohms (75ohms stated)
so I assume these are all within reasonable thresholds of variance for their purpose.
Please let me know if you think otherwise as I intend to put it all back together tomorrow (weather permitting)! :rofl: ;) ;)
Thanks again.
AndyGP
