Mot Oh No!!
:cry: :cry: Not looking forward to this. :cry: :cry:
mot due at 10.30. thought i'd adjust the handbrake a little. made things worse!! got no adjustmant left, even after taking out console and slacking nut before adjusting at wheels. now not holding car very well. :cry:
Also noticed a bit of play in rear offside wheel :cry: :cry:
could be an expensive day :eek: :eek:
nick
if its not exesive play in wheel it should pass unless deemed unsafe.
good luck
thanks.hope so but not very confident. will let you know
nick
Doesn't sound that expensive. A new handbrake cable isn't expensive and if you've got play in your HICAS arm, they're not that expensive either. Rear bearings are about £150 though, but it may not be that. Do you get play laterally as well as horizontally? Does the wheel sound rough when turned?
Blimey wot a result it passed!!!
Mot man was more interested in bling on car :cool:
had me inside car for brake test. so lifted handbrake like a weightlifter :D
never even mentioned rear wheel play. just have slight weep at p/steering pump as advisory.
well happy
gonna chill for rest of day.
thanks for the advice
