Tips for leaking targa
As above, anybody got tips for the leaks at the wingscreen end of the targa
seals
Im getting wet jeans!!
Many thanks
Allan
Try spraying Mr Sheen over the rubbers, the silicone in it makes the rubber swell, so hopefully may cure your leak.
Or rub peanut oil into the rubbers ;) Also check the targa drain holes aren't blocked up ;)
Weatherstrip sealant - MJP
Peanut Oil - Tescos
Tighten the window bolt inside the trim (behind where the seatbelt is held to the door)
...if its a jap ;)
Graham you took WAY too long to say that :rolleyes: :tongue:
:rofl:
New seals
There's always one.... an' you're all three of them :tongue: :rofl: ;) :D
earlier in the year IIRC a member put up a post with a simple how to repair leaking targa....he was using some small strips of plastic which slip under the rubbers....cant seem to find it now....anyone help out here?
seals
Many thanks
Allan
Get new Targa seals from Mike Feeney at MJP. Mine cost about £140 for both complete OEM Nissan seals. Start at the wing and go up the door pllar round the targa and finish round by yhr back of the door opening.
Time to fit about 10 minutes for first one then 2 minutes for second one cos you now know what ya doing.
Forget peanut oil and stuff and forget about leaks for the next 10 years
I installed new seals all round, still leaks! :(
Looks nice and new though LOL
Window on door needs realinement then. Or you put em on wrong or you've got a twisted monocock
Well it was very annoying to install the new seals & have them STILL leak. Maybe I'll post up some pics, & show where the water is dripping from.
seals
Many thanks
Allan
CLICK HERE.....http://www.300zx.co.uk/forums/showpost.php?p=622481&postcount=4
IT WORKED FOR ME....
Andy....
Andy....
thats the one well done for diggin it out....couldnt find it b4...did make a request back on this post ... :nana2:
  • 3 years later...
seals
Many thanks
Allan
alright al .
have a look at a post i put up a while back . really works . leaky targa fix
