A few hopefully little probs :-(
Had lots of fun getting car going -
http://www.300zx.co.uk/forums/showthread.php?t=80737
A few Niggles -
1. Hicas Light On - Fluid OK?
2. Clutch Pedal Travel - I have fitted a 2nd Hand OS Giken Twin Plate and I have not adjusted the pedal (testing stage). The pedal seems to run free about 1-2" at the top when depressing. Is this normal? Or does it require bleeding yet again?
3. Cooland Temp Gauge isnt working. I also have an aftermarket gauge and that won't read temperature either which is read from a different sensor. I though stuck thermostat but when I filled with car running steam was coming from the rad bleed hole? So Im puzzled with this as well?
Some more things to sort
4. My brakes need bleeding again, feels spongy.
5. My headlight still dont work properally.
6. Squeals for new aux belts.
Any help Guys? no.3 is doin my head in.
cheers
A few Niggles -
cheers
3. Air lock in the system, turn the heating on, and remove the bleed plug, start her up and keep filling till water comes out the bleed hole.
Tried this not thoroughly though as it was pi55ing it down, but I did see water coming out of the bleed hole screw.
Anybody give us a hint :p
The power steering fluid (hicas) is about 1 1/2 inches from the top is that enough? Its touching the big cotton bud. shall I buy some fluid in morning?
I would try to do bleed the ad again mate in the dry and leave it overnight. How long did you have it running. It took me 3 days to bleed mine up properly.
Hicas light on. Hmm fluid is ok you say? Are all the connectors to the cactuator secure at the front. The fluid dipstick should have a mark on it. Is it up to there?
Ivan
The clutch has a bleed point right down by the drivers headlight - don't forget this one. I did ^*&^%*)&^ !!!
Yep right near the hicas unit, I will bleed this again also lol, bleed, bleed, bleed........yawn lol
Do you have a 1 person bleeding kit?
No, the methood I have been doing is........
open nipple, press pedal, close nipple, depress pedal........
I saw a self bleeding gadget the other day when buying some dextron III, had a quick look at the back of the packet is said 'no need for somebody to fully press the pedal while you bleed....'
So shall I try keeping the pedal pressed down with nipple open for a while?
which do you recon is best?
Have you got some one helping you?
Thought you where doing it on your own.
4. Did you bleed the ABS unit too ?
How do you manage to bleed anything unless you have two people or a one person bleeding kit (or those cunning one person bleed nipples) ?
No Got on of my workmates to come around mine after work (22:45), he didnt leave till 2AM and his mum kept ringing him, lol.
yep done the abs unit also, the 2 nipples on top.
Am ok for a lift this week as not working stoopid shift. at home at 2:30 :)
But fall asleap on couch after tea :rolleyes:
at home at 2:30 :)
Sign of getting old mate. You need your afternoon nap! ;)
I can't be that bad as the workmate who was helping me was shattered at midnight, god knows how he goes on when hes in a nightclub.
Oh and all stuff bled when ignition on but engine wasn't running. make a big difference
Just been trying to get rid of an airlock for over half an hour, water roasting but still both temp gauges don't budge, the aftermarket one is fitted in an adaptor and the brass sensor is poking out the top where the feed wire connects to, its hot to touch, although the gauge only starts at 40 degrees I would have thought it would register??
I used my datascan cabel yesterday to look at these probs, code 55 (no problems?)
so I take it all sensors are working fine, I was concerned about the speed sensor for hicas, but no sensor faults and hicas light still on?
The water temp registered on the datascan but not on either of my gauges, is it safe to say the gauges are at fault?
