Whats the correct oil pessure ona Na..
Went for spin down to Ramsgate Engine temp Ok on the Level
Stoped and the pessure was way down...Jap inport Oil gauge Has only white line then 4 white line then 8
nornally for me about 4..
This time it stayed at white line.....
stopped Had some dinner About hour n Half carried on pessoure back up to 4.
Wots appening... Taking it in for Oil/oil flter change Thursday........Only changed last March......3000mils ago
Any Techs info.......Fanks
dunno about the marks you are on about, but with a hot engine it is normal for the stock gauge to read about 1/4 of the way accross when idling. The stock pressure senders are notoriously bad though, sometimes the gauge will randomly fall to 0 even though the pressure is fine.
Oil pessure Gauge on mine has 0 | 4 | 8
Normally Reads at 4..
but went to frist line..
Run back ok but not happy wiv it...let u know wot i find..check out sender
Ta...
if you really have no oil pressure it will blow up in about 5 seconds lol, I wouldn't worry about it, wise to get a decent gauge though.
