Moreover, can you actually get them? If so and people have fitted them, do you rate them? The steering doesn't become too harsh does it with them?
Ta
Yes, you can get to them. The one on the end of the rack with the pinion on it is really really awkward because of the pipes etc in the way. I found it was easiest to use a longer bolt first to catch the retainer then put the standard one in once you've pulled it up.
The other one is really easy.
Not sure how much difference they make as I did loads of stuff at the same time, but anything that takes some slack out can only be a good thing.
They stopped my rack from wriggling! :wack:
Does it make your steering feel a little harsh then? Just wondering how different it felt as I'm wanting to PU the rear end of the car.
Not at all mate,just stopped the rack moving as probably new oe ones would,just that Luke had em' in, £40 IIRC. :)
