I have a spare mint tailgate, that I am about to make a mould from in glassfibre, so that I can then use the buck and play with making a Carbon Fibre replacement.
I have a few questions.
1. Before I made the CF tailgate, I would make a GF test tailgate. Would that be strong enough to mount the standard rear glass?
2. Is there a replacement for glass that can be used that won't scratch like perspex?
3. Has anyone tried this before and have any tips or better still - bucks/moulds?
personally, i wouldnt like to put my faith in a f/g boot and a screen, BUT why dont you make / fit a tub into it?
all made in one piece f/g would sort the fitting issue, and be a nice touch mate
Polycarbonate.
Expect to get a poor fit though when you've finished, but good luck.
Good luck to you, FG (or CF) work can be tough but very rewarding. I might be a little concerned about the effect a lightened rear end would have on balance and traction though. Obviously under acceleration the front lifts slightly and transfers weight to the rear but under slippery/wet conditions this would be cancelled out and I imagine at high speed the car could feel a little (or possibly a lot) twitchy. Might be worth looking into different functional spoilers/ground effects to even things out? Or am I talking out of my bum? :D
Current weight distribution is 51/49 front/rear. I will have removed enough weight from the front of the car to make it 50/50 (bonnet/wings/aircon/engine internals/wheels)
so a lighter tailgate will just redress the balance.
I have no plans to use a GF tailgate - just test the mould. It's cheaper to experiment with than CF.
Also need to take into account the method and what level of finish/strength/weight you want to achieve on the final one. Autoclaved pre-preg composite parts are high quality but high cost; oven cured pre-preg composite: medium quality, medium cost; resin infusion composite: low to medium quality and likewise for the cost; wet lay composite parts: low quality but low cost.
Edit: read the post wrong the first time, lol! :D
Weave/resin/Industrial binbags/gaffa tape and a hoover to create a high pressure environment.
Don't laugh - you can make good parts like that!
Hey, if it works I'm all for the classic Heath Robinson approach! :D ;)
Best of luck mate, look forward to seeing the results :)
Polycarbonate.
polycarbonate will scratch just as easy bud!
I spoke to Chris at Getgreddy about this a few months ago and he was saying he knows someone thats doing the same project!! Great idea for weight saving!!
carbon fibre tailgate!! that would look impressive! good luck mate :bow:
Yep! I'd like one of those!! :)
