ok fitted my bovs today again .got new pipe etc so fitted all up blocked off the vacum pipe to the old ones and put the screw so it was flush with the nut on bovs took down road and still only getting 9psi not 1 bar .
what the hell is going on need help please guys ahhhhhh
bump
bump
might be selling them as i dont like the sound.
Do they actually blow off mate?-you checked there not leaking under boost?
yep you put your foot down boost hits about 9 psi (no more)
then let off and woosh put the screw in a bit more and still the same
boost gauge sits at 9psi doesnt move down etc
How were you hitting 1 bar?-ebc or jets? :wack:
ebc
Right,I can only think of a couple of things at the mo'-first you need to check you haven't plumbed the BOV's in such a way that you have by-passed the controller,ie getting standard boost!
Or secondly the bov's are too weak and letting boost go,if this makes sense?
bovs shouldnt be to week as people have used them over 1 bar .
and as for by-passing ebc havent thought of that ,like i said i blocked off the vacum hose from the old rec .the blitz manual says to leave them on and put a t piece in do you think this is a good idea???
if the bovs are to week wouldnt it woosh when you hit 9 psi etc with out lifting off
Try it the Blitz way mate,can't hurt.It could be your the wrong side of the controller,if you see what I mean?
As for the bov's,if they were weak they would leak under any boost,I reckon the problem is plumbing mate!-if it was in front of me it would be so much easier! :rolleyes: :)
Where have you plumbed the blitz bovs in Kevin??
I run them as well and have no problems
I run the vacuum to a T-peice at the front then upto the one of the pipes from the balance bar.
Mike
cheers mate it does sound like its the plumbing.should of seen you at jae damm never mind. 3rd time lucky cross your fingers
thanks once again :)
You did see me at JAE!-I ambled over why you were polishing your Z!-but I didn't know who you were LOL! :rolleyes:
Mike
ok bovs are on hard pipes .i have cut the vacum hose off the rec and blocked them off.
and drivers side come off balance bar and passanger side near pcv valve .
how far did you put the screw in???
polishing must of done that 3 times a day lol.
should of said hello . :)
Mine are on hard pipes but on where the recircs go
I think it may be the recircs that are causing it as it sounds like the plumbing is OK
May be worth trying to T the bovs together and run one vacuum source to see if that helps??
Mike
Mike
ok so i should try a t piece and have my blitz bovs and recircs working together is this correct ??
i would try T-peicing your 2 blitz bovs together and running one vacuum source and try that?
ok well i got a few more ideas from you and manta so cheers .
think i might sell them as i dont think i like that noise but not sure yet lol
how far is the screw in on yours mike
on the blitz bovs?? not sure can take i pic for you tomorrow if you want matey?
pic would be good cheers
