Is it true imports are filled with DOT 3 brake fluid?
And is a case of drain and fill with DOT 4/DOT 5 or another recommended spec? Cheers
i have no idea but i wouldent think so mine has dot 5 in it since i had it.
more than likely not
You may like to take a look at a previous post:- http://www.300zx.co.uk/forums/ubbforum/Forum1/HTML/000568.html
- Is there an easier way of doing this? This previous post also references a URL to an interesting piece on DOT-4 v DOT-5.
There are various opinions, but the view I came to was:
- I kept seeing references to DOT-3 on imports, so I should change anyway to DOT4/5;
- DOT-5 is great but not really needed for 'road cars', - "maintenance/replaced between races";
- If you go for DOT-5 you should have the system fully flushed, etc.. and replace all rubber seals.
- I came to the conclusion that DOT-4 and the SS Brakelines were for me (being fitted by my local garage today & tomorrow, along with new clutch & bushes). I will reconsider DOT-5 if/when the braking system needs overhauling, but more than likely will stay with DOT-4.
I know there are a number of other opinions, and I look forward to being shot down in flames. It's a good forum for learning more, and I really enjoy the advice & comment!
Geoff
Cheers...for info....flush then go for the DOT4 as im not sure whats in...better safe than sorry!!
