Wheel Fitment
Hi chaps,
Hope your all well. I was wondering if you guys could give me some advice on some wide alloys that i am about to purchase. The spec are as follows - 5stud 18-inch 114.3 fitment x2 Front width 10.5J/ offset F+12. x2 Rear width 13 J/ offset R-10.
My concern is whether or not the offset will fit on my wide arch conversion. Any advice would be greatly appreciated.
G.
Not sure about the rear with a widearch..but definatly wont work on the front. 10.5 wide fronts with a +12 offset would result in them sticking out several inches and ofcourse fouling.
Stock fronts being 8J with about +35 offset
sorry for been a bit fick, but can someone explain to me how/what you need to know, to find how far your wheel gonna stick out from the hub.
for instance my present wheels seem too hidden under the wheel arch so what would i need to know about my next wheels to make sure i dont get the same problem.
and how would i measure this.?
hope that makes sence :wack:
Ive got a 9" wheel on the front with a standard arch with a 0 offset rim fitted with a 235 .Thats about the limit with a standard arch dont know how much of a flare there is on the wide arch front wings .
