Potential Danger with whiteline springs (with pictures)
Ok trust me to be different.
Started to fit my whiteline lowering springs onto my nismo S tune dampers :bow: last week and noticed all was not well. :mad:
Simply put the whiteline springs are the wrong diameter to fit the 300zx dampers. :mad: :mad: :mad: They are too big.
A hurried call to demon tweeks and check of the on-line fitment catalogue confirmed that indeed the whiteline part numbers were correct but judge for yourself from the pics. would you have put these on your car? The guy said we have had hundreds of these fitted to loads of cars :shock:
Compare the first pic of the whiteline spring and how it sits on the damper with clear day light showing :x: and then the Eibach springs that i got sent next day.
Everything you need to know about the relative quality is shown in the packaging. The whiteline springs came wrapped in clingfilm :( and obviously slightly worse for wear and showing signs of ageing on a shelf / boat.
The eibachs came in a box in pristine condition.
Lesson learned.........
Now the only problem I have is the eibachs have two different numbers on each pair and no indication of which is which. Front or rear? Can anyone help
Chris
i think the wider eibachs are for the back, and the other 2 for the front... luke at zcentre knows i believe, give him a ring...
if i remember right tho once the suspension is off its pretty obvious which way they go on...
T
T
Fitted some on mine at the weekend. the springs that are alot smaller at one end are the fronts. part number ends in 001. The others are the rears.. 002
Cheers bud any idea what the other number refers to?
152314 Rear and 146777 Fronts.
Quite impressed with the eibachs on my missus RX8 so hoping they will be good with the nismo dampers on the Z
Chris
Chris
looking at that photo, yes your right. The 2 at the right hand side of the box are the fronts. Mine fitted like a glove on a nice new set of KYB AGX's. :dance:
