well i finaly got round to the 4 month water leak today,turned out to be the 2 small hoses from the block to the inlet and outlet pipes :headvswal jesus the amount of work invovled to get to the fvckers is unreal. lucky for me the car has been brought up on antifreeze all its life because the 2 stubby steel pipes were like new inside and out and the only expence was a 12" piece of 32mm samco hose to replace the oem rubber,also gave me the chance to clean the rad with degreaser front and back. back together and a 20 mile blast confirmed no leaks and a steady 78-80 degree temp :dance: total cost £5.00 for hose and £10 for coolant
Nice work! and all for a fiver! Not sure if you are talking about a different bit but lots of people do the mod to miss out all the little pipes on the throttle bodies for this reason.
no bud,the little buggers above the water pump :)
