clutch
Went out in car for a ride tonight and have had a problem :( selecting the lower gears when changing down, so i had a checked the slave cylinder and no leaks on the bottom, tried to bleed the system through( have had a problem a few weeks ago with air in the system) and i got nothing but air coming through and no fluid at all(reservoir is full).
And now i have no clutch at all which is no good as i am suppose to be going on holiday in it early sat morning :headvswal .
Which is the most likely cause to be the culprit slave cylinder or master cylinder or something completely different?????
Help is needed fast, as time really is of the essence on this one. :rolleyes:
sudden air in the system and no apparent oil leaks can be caused by several things:
- wrong oil (eg. DOT 5.x oil will attack the rubbers in master/slave cylinder causing it to leak)
- faulty/leaking bleed nipples
- worn rubbers in the master/slave cylinder. You can get rebuild kits for both from Nissan.
