Need Greddy Profec II B setting for lowest and 9psi boost
I have had a profec II B boost controller fitted by a zed garage but they did not do the unit settings as they dont have enough experience with it. Can someone please provide settings for the lowest possible boost for good economy and another for 9psi boost.
I am being conservative with settings until i get my ECU chip changed. I have read what kirbz's settings are but they dont match what i want.
Why not just set it for 9psi low mode and just not press the high button?
If you switch it off it'll run in safety boost which is the lowest you can go
No safety boost is good because it is low, about 5-6 psi I think
Ah cool, right ill leave itin 'off' mode, though it still shows boost. I will setup a 9psi setting from what other zeders have used. Get the ECU changed next month and get a HKS induction kit.
If a women cost this much id go nuts, but ma Zed is worth it :)
Safety boost is about 7 psi, but it will also retard the ignition making it extemely slow lol !!! ;)
If you leave it off, you will be running at the wastegate preset which is 7psi. Same psi as safety boost but with out the ignition retard (this isnt safety boost as you've by passed the wategate VSV which gives you 7psi)..
Car will run fine.
