Hi all,
I'm sure this is a common problem with Z's, where for what ever reason the idle will just suddenly increase when the car is fully warmed up. I just want some input on reasons you have found for this and what can be checked out using a Conzult/Datascan.
Boost leak - Boost Leak Detector
Faulty temp sensor
TPS voltage - Conzult
Closed Throttle switch (should be on at idle) - Conzult
Malfunctioning/sticky (IACV-)FICD valve - Conzult
Malfunctioning/sticky IACV regulator - Needs to be checked manually
Malfunctioning/sticky (IACV-)AAC valve - Conzult
Vijay
Yeah, I get this too. Revs rise to just over 2k.
How can the throttle switch be checked?
with a conzult
But you can reset it manually: disconnect the big grey plug coming from the TPS while the engine is idling, wait 5 secs. and connect it again.
Best is to reset it after you have verified the TPS voltage is approx. 0.44 volt at idle.
Cheers Eric. Can a faulty temp sensor be determined with a Conzult by seeing an irregular temperature?
A faulty sensor is only detected if it fails completely
A sensor giving false readings is a bit harder to diagnose.
best is to start with a cold engine and verify the coolant temp is the same (or very near) the fuel temp.
Try to find out at what temperature the idle starts to rise and go into the "main signals" menu and manually alter the coolant temperature to see if has any influence on the idle.
In general, the coolant temp on a fully warmed up Zed with a good functioning cooling system should stay at around 82Celcius
Cheers again Eric. Anything else that would cause a high idle?
Vijay
malfunctioning/sticky (IACV-)FICD valve
malfunctioning/sticky IACV regulator
malfunctioning/sticky (IACV-)AAC valve
also check the connectors of these valves (FICD + AAC connectors are hard to reach though)
>> 75c and 85c in really hot weather
is this with AC on or off ?
with AC on, the coolant temp is normally higher then normal, depending on the ambient temp it can range from 85 to 95 on a really hot day.
Cheers Eric,
Can any of those bits be diagnosed with a Conzult?
Vijay
the FICD can be switched with the conzult and is normally only used by/for the aircon.
the AAC valve can also be operated in the main signals menu of the conzult
When the engine is warmed up, the valve should be open for 15% (idealy)
The regulator valve can not be switched with the conzult (or any other diagnostic program) and needs to be checked manually
anymore reasons anyone can think of?
Vijay
