Stall
I never really though about that but I can remember turning right a couple of times and it happening
Most common cause of stalling no matter the driving manner is a boost leak.
If you know someone local who has a tester, try it and see how you get on, if not buy one of vijay they are really cheap considering the time they can save you. Oh and if you have aftermarket dump valves, most common place for leaks is in the old re circs area.
cheers
smithy
do your revs pick up when you put the air con on.?
I think so but I will check to make sure.
Have you got an induction Kit? I have heard that some can cause stalling.
Read all about it
Clicky
Yes I do. Mine only stalls at low speeds when I am going around a corner and the article says something about highway speeds.
cheers
smithy
I will check this as well. My BOV has stopped working so there may be an connection. I am still boosting as my HKS gauge reads as usual.
Yeah it sure did. I will have a look at the connections this weekend and I hope its nothing major. I have been having so much fun with it now that I can take the Tops off. How have you been?
That means nowt mate, still can have a leak and boost gauge appears okay.
It's also just a piece of mind in doing the test, which eliminates 1 possibility.
smithy
