My Project 300zx Update
Well after problems and much head scratching and umming and arring and lots of "dont worry love its only £50 honest"
Looks like i pressured my bottom end which forced oil out so i had a choice to make, do i give up or sod it its only money lets just go for it!!
So ive gone for it ;) just paid my deposit for my new engine and should be built in approx 3-4 weeks then a couple of weeks to ship over here :)
New engine spec is:
90mm Forged Pistons with full ceramic coatings
Forged Rods
ARP Rod Studs
ARP Main Studs
Block oil passages cleaned
Block redecked
Block water passage bored out for more water to back cylinders
Block Bored and Honed
Crank balanced and welded on center weight
New Rod and Main bearings (Ceramic Coated)
ARP Head Studs
Tomei 280 Degree Cams
Tomei HD Valve Springs
Tomei Solid Lifters
Titanium Retainers
Ferrera 1mm Oversized Valves
1mm Oversize Valve seats
Heads Pressure Tested
Heads oil passages cleaned
Heads redecked
Ported exhaust and intake runners
5 angle valve job
Combustion Camber work
Valve heights set
Metal Head Gaskets
OEM Valve stem seals
OEM Cam Seals
OEM Oil Pump
OEM Oil Pump Gasket
Also getting a steel 1 peice drive shaft shipped with it as well :dance:
Before anyone asks yes its expensive :smash: but tbh with the exchange rate it wasnt worth getting another engine in, ordering all the bits and building it myself.
So watch this space
Mike
  • Replies 28
  • Views 1.7k
thats going to be a rocket and a half,, what tubs you bolting to it ??
keeping my greddy td05-18g's and manifolds as they should do a good 600 at the wheels which to be honest is more than enough :) for now :tongue:
try telling er in doors that that only cost 50quid :rofl: :rofl:
its still an engine , thats all she will see ! !! as long as he does what the hamsters do at egg .com hel be fine , ie hide the statments ,quick run . do it now !!
as long as she gets a holiday in august then she doesnt care :p
bloody women, sooooo selfish :tongue:
i wish my lady was so easily pleased!!
all i want is 99 spec front, rear lights and vielside exhaust!
been told...wedding in august and buing new house nxt month so NO CHANCE
With an engine like that I'll be your wife haha! :bow: :bow:
Seriously though, top choice. Nuff respect. Can't wait to see it.
600 at hte heww, at the werhhh, at the wheerrr, wwhh wwuuuu, wwuuuuuuuahh, whwhhhhiuuu, forget it
nice one, if you do :duffer:
looks like it!! the more hp the bettter!!
which smilie?
:duffer:
:dance:
:smash:
:hyper:
:bow:
Well done mate, deffo the route to go if wanting a bullet proof engine :) looks like either a Kyle pucket spec or Z1..
cheers
smithy
So c'mon, how much will that little lot cost then?
i think once its landed will cost me around £7k give or take ;) also changing the clutch as well :rolleyes: :p
Mike
Tasty mate,would love that :bow: :cool: as Legrath said who's doing it,SPG by any chance,think your right getting it this way as exchange rate is very good,was at one time thinking same,very tempting.
Tony :)
Tony :)
Exactly tony, when i worked out all the costs of machining, parts, and the time and effort of my and my dad doing it as well as the cost of finding a perfect engine to start with, it just was not worth it :)
Roll on 6 weeks
Mike
So what is up with your current engine? doesnt that push out 479 rwbhp? and what will you be doing with it? I am looking for a project engine to build so I can keep mine on the road while I build it.
I fitted a oil catch tank which pressurised the bottom end as it was not working and when the boost spiked to 1.8 bar i think it did ring number 4 in as its leaking so i cant make anymore power!! so i decided if i'm going to complete the project and make good numbers then i wanted a certain spec to handle 8000 revs etc so i have specified my own spec ;)
I am refreshing my engine but sorry its been sold already along with my clutch ;)
Mike
is this comming from z1 m8 been looking myself.chers
no mate i didnt go down the Z1 route ;)
Mike
So you're after Macca's crown then ?
:shock: Bring it on I will have six throttle bods fitted before he is run in;)
On a serious note hope this one works out mate :dance:
:tongue:
I will just have to make do with my bored plenum and 70mm throttle bodys
:cool:
