I am getting pretty good at removing the IAA valve and have got it down to 15mins however I think I may have sussed the problem.
The plunger under the solenoid has a hole through it however I don't know which way the plunger needs to go as I assume the hole makes the idle valve work.
Does anyone know which way the plunger needs to go?
Like the picture below is showing.
Maciej
Hi Macie,
I didn't realise the brass shaft came out. Does it just pull out?
Stu
I didn't realize it the first time either. :)
Yes, you just have to pull it.
Maciej
