Lock has finally given up.
I can't lock my Zed at the moment. The drivers lock just turns and it won't lock or lock the pax door either.
When I shut the door, I now hear a rattle. Has the barrel now broken free? I tried to get the door card off earlier and had no joy.
remove seat belt, then plastic cover at top of door, (one that goes up side) beware because you need to undue bolt from outside of door, by winding window down, removing plastic bung at top to access it.
Remove window control box and unplug
Then you can unscrew rest of door card, and its clipped along the bottom
Can you get replacement parts for it? What will I need? Anyone know?
Thanks Kenny.
hi si,
if the lock has stopped working then its probaly the plastic lever snapped on the back of the door lock.nissan will only sell you this with the barrel,i was quoted £70 for one.then you have 2 keys for your car.the number on your key blade is the barrel code for the barrel.i beleive you can order this to match your key.the number has 4 digits.
For that price, I think I'll get remote central locking fitted. Cheers tho.
youll need an actuator for the drivers door.maplins sell them for a fiver.
...or one from a Zed. Nice and quiet those solendoids are. :)
z32s dont have an actuator in the drivers door.by the time youve modified a n/s one you might has well bought a new one.
