Fault codes on my ECU.
Since there have been a couple of threads recently regarding ECU checks and the fault codes they throw up I thought I'd check mine. It came up with 42(fuel temp sensor) and 34 (detonation sensor), is this bad? I've not noticed any difference in performance or any untoward noises, does the ECU store codes and then need resetting in some way or do I have an expensive problem to fix?
You'll be in safety mode (retarded Timing, 6.5psi boost and richer fuel maps), probably since last owner had it. Once fixed there is a massive difference in performance :D Have seen a drop of 80-100hp in safety mode on the Rolling Road.
New Fuel temp sensor, and bypass the Det sensor.
i always thought if you have a det sensor curcuit showing that it ran in safety boost
corrects its self when ignition is turned off then back on but will still store fault
the ecu will log faults for 50 engine starts then if the fault is not current then it is deleted.bridge out the plug to the det sensor with a 100 ohm resistor from maplins.this is not recommended if you dont know what detonation sounds like as you could melt a piston.it will prove that the wiring is good back to the ecu if comes back code 55,no faults.
jason
How? Where? Or would I be better off taking it to Ztech?
