Boost leak on oil system
OK, my english is not prefect so I will try to explain the best way I can.
I've bought a boost leak detector. I've tested it and find some leak that as been solve now.
But when I put the system under pressure, if I pull out the oil level gauge (can't explain better ), i lose all the pressure.
It's mean, the pressure I'm building with the boost leak detector is going onto the oil system. Is that normal?
Also, my car is running fine and really powerfull but sometimes, it's smoke.
Does my turbo are burned?
Thank you
