Why do I have oil on my balance pipe?
I've found that my balance pipe is full of oil.
As I already told you my car is smking a lot.
What is my problem?
PCV valve?
Turbos?
What is my problem?
PCV valve?
Turbos?
sounds like breather related,check hoses and valves then go from there
Hoses and valve of the PCV?
yes
a PCV valve stuck open or not sealing 100% can cause pressure in the crankcase, causing the oil to be blown out into the intake/plenum or through the dipstick and crankshaft seals
I've found that my crack pipe is full of oil.
What is my problem?
PCV valve?
Turbos?
Sounds like your car has a bit of an addiction, start by weaning it off of the stuff slowly. :wack:
On a serious note, ones in a rubber pipe just down beside your battery tray on the side of the engine towards the bulkhead. One end has a large Hex nut on it (the end facing front of the car) the end at the back nr bulkead is just pushed onto a copper L peice. The pipe is probably only 5 inches long if that.
IIRC to locate the other one look under near where the CC unit is, similar place basically on other side of the engine. If I remember rightly one is smaller in diameter than the other.
Cheers!
FPMSL steves home :tongue:
